Lube for Plastic Threads
I need advice on lube for 3/8-16 stainless (type 304) bolts assembled into female plastic threads. Material is nylon and appears to be glass filled. Threads are tapped and have been re-tapped to clean up some of the burrs. These pieces are U-Clamps to hold short pieces of plastic pipe together in a process washer/zinc phosphate system. Much of the assembly will be in tight quarters and out of position, so we want to make the bolts assemble as easily as possible.
RE: Lube for Plastic Threads
Yates--for graphite, do you mean dry or solvent based?
http://www.nyelubricants.com/index.htm
