IEEE 112 Testing
IEEE 112 Testing
Hi guys can you tell me the difference between testing motors between IEEE 112 Method F & F1
RE: IEEE 112 Testing
In North America the electric motors are tested in accordance with IEEE 112, But you can find this methods: B,C,E,E1,F and F1.
In The F method is not neccesary to couple up the motor and a is necesarie to perform a Dual-Frecuency heat run and use
stray loads.
The F1 method use an assigned value to the load loss.
Petronila.
Basically in Method F, Stray Losses are measured, and in Method F1 are calculated or assumed!
Is that correct?
As Tommy007 said; On method F the stray-load loss is directly meassured. For method F1 stray-load loss is assumed
