Printing issue survey
Looking for feedback on what others are doing. We have 60 people that can print to multiple prints/plotters. The issue is one day a person will print a drawing on 11x17 and is happy. The next day they try to print 11x17 and get it on 8.5x11. I'm sure some settings were changed or they changed printers but it always seems cumbersome to get exactly what you want.
When we used ACAD we had a pulldown that you could select Plot A, B, C, or D and it would automatically set the setting to what were needed.
Are you having to go to something like this for SW or what's everyone doing.
We're running SW 06 SP2.0
RE: Printing issue survey
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Don't know why.
(templates are set up as 11 x 17)
dsgnr1
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Bradley
I have trained myself to use print preview then print if it looks right.
As far as setting templates for the different sizes, it doesn't help if you have mixed sheets in a drawing packet. We use 8 1/2 x 11 and 11 x 17 sheets, and the easiest way to print a drawing packet with mixed sheets is to save it as a PDF and print it.
The other way is to print sheets 1 to 20 as B size sheets (for example), then change page setup to A size sheets and print the rest.
Flores
SW06 SP3.0
