how do I change the radius of a spline through points?
I am making a spline through a series of 3D points.  In the spline options, I pick 'single radius' and the spline is made as a series of line segments connecting the points, with a corner radius that I assign between each pair of lines.  The problem is, that pro-e limits me to a radius of no less than 1.5 inches.  What if I want a radius smaller than that?  Why the limit?
RE: how do I change the radius of a spline through points?
Sounds to me like the limit is particular to the geometry in question. Does the limit change if you modify the coordinates of the points (just as a test)?
Try changing your relative accuracy from .0012 to .0001. By the way, I assume you are making a straight line throu points with arc, rather than splines, which dont require arcs.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
Sounds like an accuracy problem to me too.  There is no theoretical lower limit to the radius but there is an upper limit depending on the point positions.
Thanks, 3dlogix, changing the accuracy worked.  Appreciate the help!
