FloWorks Std / FloWorks PE (SW2004)
Hi
would someone be able to direct me on how to get FloWorks PE operational instead of the Standard version I'm trying  to work my way through the Rotating Impeller Tutorial, as the Wizard does not display the Rotating Reference Frame window as per the Tutorial. I remember when I first Run the program some time ago that a pop up asking for Floworks Std or PE I think my choice then was the Std version, I have tried removing & reinstalling this without success.
any ideas
TIA
Thomas
RE: FloWorks Std / FloWorks PE (SW2004)
it depends only on what license you have. Considering that you're not running a cracked version winky smile , if you have the license for s STD version there will be NO WAY to run FloWorks in PE mode.
Running in PE mode with a cracked version is another thing, I may know it very well but you'll never see me post this kind of solutions HERE... winky smile
