ACAD 2006 Block
ACAD 2006 Block
Hi, I'm Italian user. (Sorry for my bad english)
Can I make block that it includes some normal object (lines, arcs, circles ...) and some Autocad standard parts (screw, bolts, ) ?
Thanks!
Thanks!
RE: ACAD 2006 Block
RE: ACAD 2006 Block
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: ACAD 2006 Block
When I make a block (with _block command) and I include some object and some standard autocad part, the standard parts selected are not includes in the block! In the command line it appears "filtered object".
My question is: Can I disable the "filtered object"
