How to open Input file (*.inp)?
Hi all,
i have read the ABAQUS Example Problems Manual. I found a lot of input file(*.inp). I tried to open it in the Program using command:Import ---Model . The result that I got is Empty part.
I would like to ask you, Do you know,How to open it?
Thank you very much for your answer.
Jojoe1973
RE: How to open Input file (*.inp)?
Please use the notepad in windows.
copy from manual to notepad. Save file with .inp extension. Make sure its not txt extension and then open it in abaqus using import.
Thank you Geosmith and Harry123456
I can open it.
