diameter of air core in hydrocyclones
iwould like to calculate the diameter of the air core in hydrocyclones by taking its photograph using high speed digital camera from aperspesx model. But i am told that the diameter thus obtained may not be the true diameter  due to refraction of the lighgt rays from water and perspex. Any idea how this can be done
RE: diameter of air core in hydrocyclones
Hi Sripriyarajendran
if you precalibrate your transparent cyclone by filling it with water, and taking photos of known dimensions within the cyclone, you will be able to correct for any refractive effects during operation.
Cheers
Steve
Standard, properly operated hydrocyclones don't have an "air core."  They are completely liquid filled.  Any air present at start up is quickly swept up in the overhead.
