PW rendering fails to save
We have been having an intermintant issue the last couple of weeks. We save a PW rendering and everything works as normal. The processing dialog box does it's count down and we recieve a message when the rendering is done which says somehting to the effect of "your rendering saved succesfully, blah, blah, blah" . This is all normal behavior. The problem, when you go and find the saved rendering file it's empty, It actually won't even open and the file size is a ridiculously low number like 100kb. I can't seem to pinpoint any sort of pattern to the problem it just happens intermintantly. Is any one else seeing this or have any ideas?
TIA
TIA
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com
SW 2006 SP 2.0
RE: PW rendering fails to save
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Rob Rodriguez CSWP
President: Northern
SW 2006 SP 2.0
Just more things to check.
I also thought it may be the size of the file (image too large) but that wasn't the case either.
Thanks for the thoughts Matt. I have the feeling this is going to be one of those things that never gets figured out like Roswell and the meaning of life.
Rob Rodriguez CSWP
President: Northern
SW 2006 SP 2.0
Jeff Mowry
Jeff Mowry
Ahh, I get it now ... "the meaning of life"
Sorry, I'm a bit slow this morning. Need more
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Rob Rodriguez CSWP
President: Northern
SW 2006 SP 2.0
