pressure duct
pressure duct
pressure duct
I have a situation where the static pressure in the exhaust duct system is about 40 inches. I am not sure how to determine if I should use a 14 gauge duct or a 16 gauge duct. Any help would be greatly appreciated.
Thank you
RE: pressure duct
What is the application? Does sound matter? Thinner gauge will tend to 'tin-can' and make more noise when the fan is cycled. Is the fan cycled?
Tell us more about the system.
RE: pressure duct
The application is a dust collection system. The duct from the various pieces of equipment is taken to a bag filter and from there to a carbon bed and then to a second carbon bed before the air is discharged by the fan. The bag filter has a pr. drop of 5 inches, and each carbon bed has 10 inches of pr. drop. The duct in question is between the filter and the first carbon bed, between the carbon beds and then to the fan. The duct is 18" round.
RE: pressure duct
This is a question for a mfr such as United McGill.
RE: pressure duct
Check the SMACNA manual.  It should have recommended duct gauges for the pressure you want.
