Welded AND Bolted Joints
Are welded and bolted joints a bad combination, or can they be used successfully together?
Or is it bad practice. If so, or not, will you kindly give me an example?
I would imagine if the weld was weaker than the bolted joint or vice versa it could be an issue?
Thanks in advance,
13
Thanks in advance,
13
RE: Welded AND Bolted Joints
Very well written and covers both welded and bolted or riveted joint design, and load capacity.
http://www.boltcouncil.org/guide1.htm
No such luck, though with my refractory bend table questions!
