Max flow rate
Max flow rate
Max flow rate
Hi
I need to find the maximum allowed flow rate for fuel oil in steel pipes
I'm looking forward to getting some help
Project engineer
KDK
RE: Max flow rate
kdk:
I don't know of any "maximum allowed" fuel oil flow rate in steel pipes. Allowed by whom??
As a rule of thumb, the velocity of the fuel oil should be kept between 2 to 3 meters per second.
Milton Beychok
(Visit me at www.air-dispersion.com)
RE: Max flow rate
hi again
I know about the thumb rule, but can anyone tell me why its 2-3 meter per second and not 4-5? and where I can find information about the subject?
By allowed I’m thinking about ship classification companies
RE: Max flow rate
I would reccommend that and engineering/economic feasibilty study be performed.  General rules are fine for guides, however, stockholders/  consumers need the best they can get with regard to the environment, safety and cost.
RE: Max flow rate
kdk:
A good many economic studies (such as suggested by Sailoday) have been made over the years, and the 2-3 meters per second has been determined to be the best compromise between pipe capital cost and pump operating costs.  Of course, there may be special circumstances in specific cases that might warrant yet another economic study.
Another factor to be aware of is that higher velocities increase pipe erosion problems.
All in all, the 2-3 meters per second rule of thumb has served many of us well for many years.
Milton Beychok
RE: Max flow rate
For an interesting discussion "Best Diameter of Pipe"
see thread 378-8302
RE: Max flow rate
In the storage tank world the flow rates will be kept to about 2 to 3 feet per second (not metres per second)if discharging into an empty tank.  This is done for safety reasons due to a build up of static charges.  Once the discharge end of the pipe is submerged normal flow rates are resumed.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
RE: Max flow rate
Thank you for the information Steve
Do you know where I can find some more information/rules about the subject
KDK
Project Engineer
RE: Max flow rate
API RP 2003 has some information regarding static charges and flow velocities.
