Basic math in Autocad?
Is it possible to add/subtract/divide, etc... on the command line (Something like .4136/2 to get .2086)?
RE: Basic math in Autocad?
Yes, using the CAL command. To use the result of CAL in a command, call it transparently with 'CAL (a leading apostrophe)
You  can also use lisp statements on the command line, you just need to learn its syntax -enclose in parentheses, operator first.  Your example:
(/ .4136 2)
be careful in division, if you use all integers the result will be an integer, for example
(/ 5 2)
  will give you 2, not 2.5
Thanks, thats exactly what I was looking for.
