Need model for 5 Gallon pail with lid.
Need model for 5 Gallon pail with lid. Does anyone knows where to find it?
RE: Need model for 5 Gallon pail with lid.
Check the FAQ section for websites.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Checked it already with no luck.
I can settle for just the pail at least with no lid.
They're not too difficult to model--you could probably model it fairly accurately within a half hour.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Curious ... if you don't have the SW skills, what do you need the pail/lid for?
Chris
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Sorry for the misunderstanding I've been working with SW2004 for about a year now.
I just don't know how to draw every single part. (just learning sheetmetal and Lofted Boss Base.
Thanks anyway.
You may want to do it as a revolved feature--then add the particular details after revolving the basic shape.  That's probably the simplest way to do it.
Jeff Mowry
Moulded Plastic?
Deep Drawn or Spun?
Roll Formed & Wrapped with Seam?
I suggest you obtain an actual pail & lid of the type you need, then measure & model it.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
