Another Ball Joint question
I constructed a simple ball joint and used a concentric mate to the two spherical faces. This works fine and gives me full 360 deg rotation, but the ball has a shaft sticking out of one side. How can I limit the mate so the movement of the ball and shaft in any rotational direction will stop when the shaft comes in contct with edge of the female ball joint
tom...
tom...
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: Another Ball Joint question
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Tom..
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
[URL=http://img
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
This Forum is great...
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
thanks for the tip. I tried this and it works great. But can you turn on collision detection from a system level so its just always on if you want to?. It would also be cool if you could select geometry as a boundary option rather than entering a distance or angle for limit mates. In my case a concentric mate is good for the movement of the ball joint, but it would of been cool to just select geometry (edge or face) to establish the limits of movement. this would be similar to collision detection..
tom..
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
