Best way to Make numerous holes in concrete
Hi all,
We have an application where we need to bore numerous holes into an existing concrete slab.
Hold diameter will be ~40mm, Reinforcing may be present but structuraly not a problem if we go through it.  Depth of about 200-300mm.
Need to bore around 4 sets of 15 holes.
Is a diamond tipped core drill our best bet or are there other methods?  Not too concerned about he surface finish as we will be using chemical anchors.
Dave
RE: Best way to Make numerous holes in concrete
Happy New Year.
The fastest method to do what you want to do is to use a rock drill with a whirlibit but they typically only drill up to a 1 1/2" diameter hole (38.1 mm).  Otherwise, the diamond core bit is your best bet and offers better precision.
