Differential trip
Differential trip
We have a transformer that deliver full load current, but trips on through fault. The relay is Duo-bias (Reyrolle C21)
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Differential trip
What kind of CTs are you using?
Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
Describe the scheme properly. Particularly CT locations, and ratings. Describe the transformer, at least in winding configuration and ratio. Remember that the only information we have about your problem is what you post, so if you don't expressly tell us about something, then we don't know.
Your body might be a temple. Mine is an amusement park...
Actually the transformer is 15MVA, 132/11KV and Y/Y. The primary CT is a bushing CT of ratio 100/1A and the secondary is a panel CT of ratio 1200/0.577. We have sets of interposing CTs on both primary and secondary wired in star/delta. There is REF on the primary circuit.
http://w
The 13th page of the 15 page booklet on the 2C21 / 3C21 shows a typical connection for a combined differential / REF scheme sharing the same primary CTs. My guesses based on the symptoms you describe are: CT saturation as Ralph has already identified, or your neutral CT might be reversed. I am cautious because you don't state whether or not the REF relay also trips when the diff relay trips, and you also don't specify the nature of the through fault. Tell us whether the fault is phase-phase, single-phase-earth, 3-phase-earth, etc. This is very significant because if the scheme is stable for certain faults and unstable for others then that gives a great deal of help diagnosing the problem.
If all this proves correct, do a saturation test of the CT's
You still do not supply much info.
From the kind of relay you are using I suppose it is an old installation. How long do you experience this fault? Is it a recent fault?
Combined REF and differential schemes are not unusual. If the scheme is stable on load currents, but unstable on through-fault currents, I would still suspect a wrong CT - most probably a CT that saturates under heavy current conditions. Also remember that these CTs have to be class X CTs. I would not suspect a reversed CT, because then your scheme would be unstable under normal load conditions.
Number of factors that need consideration for a differential scheme on two winding transformer:
a) Transformer vector group (phase shift between HV and LV)
b) Mismatch of HV and LV CTs
c) Varying currents due to on-Load Tap changer (OLTC)
d) Magnetizing in-rush currents (from one side only)
e) Possibility of zero-sequence current de-stabelizing the differential for an external earth fault.
Factor (a) need no consideration, because there is no phase shift between HV and LV. (Transformer Y/y)
Can you confirm that your main HV and LV-CTs are connected both in star? Interposing CTs (both star/delta) seems to be fine.
The delta connection of the interposing CTs provides a path for circulating zero-sequence current, thereby stabilizing the protection for an external earth fault as required by factor (e)
Seems to be fine
As the magnetic inrush is predominately 2nd harmonic, filters are then utilized to stabelise the protection for this condition (d)
No inrush trips, seems to be fine
It is necessary to bias the relay to overcome current unbalances caused by (b) mismatch of CTs and (c) OLTC. The desired setting is dictated by the operating range of the OLTC which is responsible for the biggest current unbalance under healthy conditions.
Seems to be fine because transformer operate under full-load conditions
This will ensure CT ratio, connections etc
Subramanian
What we observed is that the primary CTs saturates earlier than the secondary CTs. The secondary CTs are of X class while there is no name plate for the primary CT but we believe the class to be 5P10. Our relay is an old one and does not have provision for altering the bias setting. We are now trying to replace it with one whose bias can be adjusted. Will this help us in any way?
Thanks for the feedback - we can all learn from such a problem. I am glad you found it.
Regarding your last question:
If you want to replace it with a new microprocessor relay you can leave the main-CTs just as they are. Most of these relays have also REF-funtions (low impedance) incorporated into the relay. With the new era of relays there are much lower burdens imposed on the CTs and the need for dedicated (class X) CTs are not necessary anymore.
Sorry, I should have been more descriptive.
Class X CTs are included in the old British Standards, BS 3938:1973. (I think it changed to Class PX in the new IEC-standards, but I am more familiar with the old term) It cover protective CTs for the use in applications where the required characteristics of the CTs cannot be conveniently expressed in the terms used for classes 5P and 10P. (like in dedicated protective schemes, such as differential scheme)
Class X CTs are spesified in the following terms:
a) rated primary current
b) turns ratio
c) knee point emf
d) exciting current at the knee point emf and/or at a staded percentage thereof.
e) resistance of the secondary winding, corrected to 75°C or the maximum service temperatue, whichever is the greater.
Ralph
Vkp - Voltage knee point
Io - Maximum magnetising current at Vkp
Rs - Maximum resistance of the secondary winding
I don't suffer from insanity. I enjoy it...
We are having to replace the Class X neutral CT in an LV generator REF protection scheme.
I have nameplate details of the original CT, but the CT that has been offered by my supplier has slightly different characteristics - i.e. Resistance @75deg C was 13.3ohm, CT offered has 9.8ohm, Vk was 600V, CT offered has Vk of 605V etc
Any comments would be appreciated!
Allan
Gut feeling in the absence of all the design data is that the alternative CT will be ok. The differences in spec that you've listed are all in the 'right' direction, so you should be ok for those two parameters as far as I can see. Presumably the ratio is an exact match? Can you confirm that the CT resistances are both quoted at the same temperature? Also consider the magnetising current for the CT and see how this compares with the original.
Out of interest, was it not possible to save the core of the original CT and rewind it? What is the primary rating?
Thanks for your comments - that's along the same lines as feedback I have had from our relay supplier.
The ratio is an exact match (1000/1), CT resistances are both quoted at 75deg C and the FLC of the circuit is around 870A. I will check with the vendor re the magnetising current of the new CT.
The reason for replacing the existing neutral CT (mounted within switchboard) is that it was damaged during modifications being made to the generator incomer cubicle.
