Voltage drifting
Voltage drifting
I have a strain gauge connected to a metallic rod hinged at one end. The system detects the bending of the beam(when I press it with my hand, as seen by increase in output voltage) but even before touching the rod, as I bring my hand close to the rod the output starts increasing (offsetting from zero point) and decreases to normal when I move away from it. The change in output voltage due to this offset is greater than that caused by bending. It seems almost as if the grounding of the system changes. I tried insulating and shielding the circuit, wires and beam(with aluminum foils, tapes etc) but still the systems offsets as soon as my hand or body comes close to the rod. I am trying to understand the reason for it and if there’s a way to solve this problem.
RE: Voltage drifting
Mike Halloran
Pembroke Pines, FL, USA
Without direct knowledge of the setup it is difficult to comment but look at how you can bleed a capacitively coupled charge away from the amplifier input and ensure that a balanced connection is being used. Earth the rod as well.
kch
You also might try wearing a properly grounded ESD coat to eliminate the capacitance possibility. If it is displacement current, inserting a high value reisitor to ground in your signal conditioning circuit might bleed it off. Likewise if your coupling at a specific frequency you might be able to shunt that to ground with the right sized RC filter.
