How does a Clutch bearing work?
Hi Guys:
I'm a EE ( sorry!) trying to understand how roller clutch bearings work. Knon of any sites that have a "how to" on these parts?
I have a Torrington roller clutch on a piece of old exersize equipment that in now "slipping" ( backlash?) in the torque direction.
I'm not sure if the bearing is shot or I just need to re-pack it or lub it, something
I found replacement parts on the web, but I'm not sure if the current part is bad or in need of maintenance.
Any suggestions?
Ralph
Any suggestions?
Ralph
RE: How does a Clutch bearing work?
The bearings were working well before but now are slipping. So I assume all the alignment ands upport were ok at one time.
Can these types of bearings wear out over years of use?
If so can I just replace them and hope for the best. Or do I need to turn down new shafts and replace all parts not just the bearings.
Ralph
