Save NX3 to NX2
Save NX3 to NX2
Save NX3 to NX2
Is it possible to save a NX3 file in NX2 format directly?
If possible, will I loose all parametric features? 2D drawings?
Carlos Saraiva
RE: Save NX3 to NX2
I doubt, I don't think a possibility to save to previous versions in UG
RE: Save NX3 to NX2
You can not save a current version part to a previous revision.  This is true of most, if not all, high end cad systems.
You can export your model as a parasolid and your drawing as a dxf or dwg.  No parameters, though.
