Turning through + - 90 degrees with cv joints
Would any engineer in his right mind use a series of cv joints to turn a driveshaft through 90 degrees instead of using a right angle drive? The intermediate support shafts would have to be anchored.
If say 70 degrees is required - would it be done?
Any examples?
RE: Turning through + - 90 degrees with cv joints
The Citroen SM uses two CV joints at the outer ends of its axles to get steering lock like a London taxi.  I'm not clear on how the intermediate shaft is supported; perhaps by the sphere that encloses the entire double- joint assembly.
Mike Halloran
Pembroke Pines, FL, USA
But that is only likely to be 45 degrees max.
Some agricultural equipment uses double cardans on the PTO shaft to get fairly weird looking angles, but again, probably not much more than 45 degrees, and again, without a direct support of the intermediate shaft.
Cheers
Greg Locock
