Flange Face Parallelism Standard
Does anyone know of industry standards addressing parallelism of flange faces prior to installation? We have experienced a cracked fillet weld at the socket connection of a short lap-joint flange hub into a rigid pressure vessel. During installation, as the raised faces (piping flange and hub) were drawn together, the weld had to resist the strain-induced stress required to make the out-of-parallel RF faces parallel. The fillet weld complied with ASME BPV Code standards, but apparently that was inadequate to handle the structural bending load.
RE: Flange Face Parallelism Standard
Pipe Fabrication Institute
ES3- "Pipe fabrication tolerances"
www.PFI.org
Try
pfi@pfi-institute.org
http://www.standard.no/imaker.exe?id=1358
Steve Jones
http://www.pdo.co.om/pdo/
Figure F-1 for External Dimensions, Nozzle and Support Locations
and, just for general culture...
Figure F-2 for Tubesheets, Partitions, Covers, and Flanges.
Cheers
saludos.
a.
Thanks to rconner and cvg for their anecdotal input.
Our objective is simply to establish the amount of strain that the weld connection of a flange hub would have to withstand when our flange is drawn to an axially aligned but out-of-parallel rigid flange face. We would hope that we can avoid a limitation on horsepower of a backhoe used to draw the flange faces together
