electrical engineering in Canada
Hi all , just to finsh my masters in EE and my topic is in indoor propagation memasurment techniques amd systems , to find a job what can I do , all want 5-7 years experince and no one in canada will give my experince , shall I sacriifice what I learned , it is a very difficult decison , any advice from comapnies and engineers in canada in ym field to help me plz
thnaks
thnaks
RE: electrical engineering in Canada
GoodLuck in your search for a job!
Just follow this simple three step process to getting a job.
1) Make up a pile of resumes. (Get them letter perfect with no typo’s or misspellings or grammar errors, get professional assistance in writing one.)
2) Research the engineering firms in your area, know what each one’s strength and weaknesses are, who is in charge of the electrical department and what some current and major past projects are.
3) Go to the key individuals at the researched companies, dazzle them with your brilliance and knowledge of their firm and the local industry and ask for a job.
Step three may have to be repeated many times until successful.
The beauty of this process is that it works for any and all entry level jobs with no regard for discipline.
Good luck (which is what’s left after the sweat of hard work evaporates.)
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
This is simply too much for the companies to pay out to recruit junior unproven personnel who will often not stay long or even be productive for a while.
They hire new grads the most economical way, usually word of mouth, walk ins, unsolicited applicants or applicants from job fairs.
Use these routes to reach the decision makers who do the hiring. Remember that your best chance of getting a job increases with the more resumes out there. Several hundred would not be out of line.
Because if you’re not working then you might as well be working on finding a job. Treat it as a full time 40+ hours per week task until you find something.
Don't expect an immediate payoff for the time invested, but the friends and contacts you make by working with these organizations sometimes last a lifetime.
If your English isn't good, why would an employer take a chance on you even if your technical skills are excellent? If the answer is merely that you will work for a few thousand or even a few tens of thousands of dollars per year LESS than someone who doesn't have this deficiency, that's not enough of a lure for most current employers unless they are desperate for your particular technical skills. The supply of desperate employers is pretty minimal in the current oversupplied marketplace. A large fraction of Canada's engineers work for firms in which there are fewer than five engineers, and many of those who hire engineers are not engineers themselves, further complicating your problem.
Look at www.geocities.com/martinsmoltenmetal/index.htm to get some perspective on your situation in composite terms. You are applying to work in a massively over-supplied marketplace. For your best chances of success you need to get outside the major population centres of Toronto and Montreal where there are literally thousands competing for the same jobs you are looking for. It is quite likely you will have to put your engineering dreams aside for a time until you master the communication skills and cultural/business understanding necessary to work successfully as an engineer in Canada. Or you might find a job tomorrow- who knows- thousands of recent immigrant engineers ARE successfully integrated into the marketplace yearly. (the problem is that fifteen thousand more come each year!)
What Canada has provided you with is an opportunity to integrate into an unregulated economy in whatever capacity you can, not a guarantee of a better life. I wish you the best of luck in making the most of that opportunity.
thnaks
Mike
I'm sure the same situation will apply to me if I were to try and find work in your home country, I doubt many employers will look twice at me if I had a hard time with the local language.
The best advice I can give you is to either find an excellent English speaker (excellent is NOT fluent, it is BETTER than fluent) to type up a good cover letter for you, and to enrol in some advanced English classes, or to spend alot fo time watching English shows on TV and repeating the words.
Good luck.
The majority of them use a lot of slang and improper grammar.
To improve your English skills the only TV shows are the highly acclaimed ands well written ones such as West Wing or the news shows (actual news shows, not the entertainment ones.)
Read a lot of good literature. Not only the classics (which may teach you archaic usage) but the well written ones by authors like John Grisham.
Don’t worry too much about any accent unless it makes it difficult to understand what you are saying. Most Canadians will be very tolerant of an accent.
I think any TV show is an excellent way to learn a language, slang or not, actually hearing and repeating words helps you to learn a language better than just reading the words and pronouncing them (how do you know you're pronouncing correctly if you haven't heard the word).
Besides slang is a prevalent part of the English language and like it or not it is commonly used.
As for formal English....how many people do you know that talk like the news anchors?
One of my good friends came from the middle east and managed to learn near perfect (ie. Canadian ?) English in very little time just by watching TV shows and repeating the words, I find that my Spanish language study improves when I watch Spanish shows and repeat the words.
Cheers
Greg Locock
My intention however is not to paint a picture of doom and gloom. Infact my friend (he finished his bachelor's abroad and his masters in Canada found a job recently and is doing well for himself. But all that I'm saying is that its not impossible but very hard. Especially if you're in the VLSI/embedded systems/FPGA design stuff.
The fact of the matter is that availability of jobs for engineers or any other profession are defined by markets and the rules of demand and supply. The trick is to find a job or a career that is in demand in canadian markets..if thats indeed were you want to live....no point of learning agricultural techniques for growing palm trees if you reside in the arctic circle.
This is why I've recently decided to diversify my EE background and get some training in the petroleum industry as its very big in Canada and is expected to only get bigger.
As for language, yes get training for it...( in my opinion, english is one of the easier languages......) the best way to learn any language is to practice with other people.
good luck with ur job search!
halherta
