DRAWING-PASTE AT CORD
at my old company when I copied text or lines from 1 drawing and pasted them into a new drawing we had a mapkey set up so it pasted them at the exact same coordinates
can anyone help me figure out how to do this
thanks
RE: DRAWING-PASTE AT CORD
Copy and Paste referencing abs coords 0, 0?
i tired that it also needs more input like picking a point at the bottom left corner i am probably being anal here but i would like to it be exactly pasted from where i got it
sometimes i copy lines from one drawing to the next and would like them to line up exactly
this can be done
mechbull
Try this one out:
CODE
mapkey copycoords @MAPKEY_LABELCopy to same coordinates;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdEditCopy.edit_t`;\
mapkey(continued) @MANUAL_PAUSESelect Destination sheet and click to continue;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdEditPaste.edit_t`;#ABS COORDS;0;0;\
mapkey(continued) #ABS COORDS;0;0;
To use it:   Pick the note, then activate the mapkey. A dialog will pop up telling you to pick the destination sheet and click to continue. So you need to switch to the drawing/sheet, and make sure you click on the sheet itself so that the paste button isn't grey. Then when you click to resume, it will automatically reference the 0,0 coordinate of each sheet.
Thanks for the idea, I'm adding this one to my arsenal :)
i think your close to what i want
what i am trying to do i take notes or geometry from 1 drawing into a completely new drawing
also the mapkey i used went like this
1. highlight notes, geom, views or anything
2. right click hit copy click off
3. go to new sheet or new drawing
4. launch mapkey
this worked with pro intralink having two dif work spaces going 2 dif drawings if any of this info helps
That mapkey should work for anything but drawing views.
If you want to copy just the view (as is.. no link back to the model), you can select the view and hit Edit-->Convert to Draft Entities.
Then you can execute the mapkey and plug the geometry on its own into a new drawing. But.. you lose all associativity. I do something similar when I make a layout file from an existing Pro/E model.
here it is
mapkey pac @MAPKEY_LABELpaste at coordinates;\
mapkey(continued) ~ `Edit`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Edit.psh_dwg_paste`;#ABS COORDS;0;0;#ABS COORDS;0;\
mapkey(continued) 0;
after you high light and copy a note line etc...
create this mapkey it will let you paste at abs coord from any sheet to sheet or any drawing to any drawing
