Generating a helix around a radius in SW
Does anyone know how to properly model a compression spring that is placed in a cavity that bends the spring to the cavity shape?  I cannot get the sweep with twist to work properly or the flex or deform functions.  Has anyone ran into this problem?
RE: Generating a helix around a radius in SW
You can model a bent spring.  It will take some extra steps to model it compared to straight springs.
If you really want to do it, you can create a straight spring with triangle or diamond shape wires.  Then apply "FLEX" feature to bend the spring.  Create a compound curve using one of edges.  Create your new spring using this compound curve as path together with a sketch of a small circle (wire cross section).
Alex
I was hoping to get a x,y,z curve based off of some mathematical equation and do a sweep of those points.
Rgrayclamps,
Are you saying that if you start with triangle or diamond shapes when you hit the flex feature, the shapes will distort and become round?  I am confused.
Hi, McDesign25:
No, "FLEX" feature will not distort a triangle or diamond shape into round.
If you create a spring with triangle or diamond wire (make sure one of corners coincides with your helix), it will create an edge equivalent to your helix.  So, when you apply a "FLEX" feature, it will bent this edge (a helix)into a new edge that you can use as a sweep path to create your new bent spring.  Of course, you need to create a new sketch with a small circle (your round wire) to do your sweep.  The trick here is that "FLEX" can not bent a helix curve, but it can bent edges/bodies.
So, you will get two bent spring bodies.  The first body is a bent spring with a triangle or diamond shape wire.  The second is the bent spring you want.  You just need to suppress the first one.
Good Luck!
Alex
Another option is to deform the spring.
