preheating for interpass for welding
hello,
we did the first pass of vertical weld in storage tank but becuase of raining we stoped the work.after 2 days we started to weld the socand pass without any preheatig and the ambiente temprature was 5-10'C .our refrence standard is API650.for second pass the plates was dry.
can this sequence cuase a problem in our work and is it against the standard.
RE: preheating for interpass for welding
Steve Braune
Tank Industry Consultants
www.tankindustry.com
Steve Jones
http://www.pdo.co.om/pdo/
You state... "addition for former questions our standard is API650 and shell thk. in first shell is 20mm and preheat temp. which is mention in WPS 30'c"
API-650 requires that welding be done above 0 degrees C; otherwise, preheat is required. Also, there are additional preheat requirements for plates above 32mm.
Since welding was done above 0 degrees C and the plate is only 20mm thick, I do not believe that you have a problem with API-650.
Notwithstanding this minimum requirement for preheat, the welding is to be performed following a WPS that meets the API minimum requirements. It sounds like the only problem you have is the the contractor did not follow his own WPS.
Hope this helps.
Steve Braune
