PDMWorks Slow Check-in
We are experiencing a slow check-in time on assemblies that have toolbox references.  What I have found on our testing is the hang occurs when it is sending the final upper level assembly to the vault not the fasteners.  The reason I believe toolbox to be a part of the problem is that if I reference the fasteners locally rather than across the network the assembly will check into the vault in a reasonable amount of time.  I am talking about a difference in time of a couple of minutes to 15 minutes.  I am wondering if anyone else has experienced this kind of problem?
RE: PDMWorks Slow Check-in
Specs, version (SP of SW and PDMworks), Type of networks (Novell or windows 2003 server).
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
chonzik,
In addition to what Scott is asking, what are your settings for copying toolbox files to the vault?  That could have an impact on performance.
