problems with autochain on
hello guys
i'm having a problem with i-deas 11 nx. can anyone help me?
when you do 2D a box, it have 4 lines(curves) that will be the edges, but, when i try to make a extrusion, if "autochain" is checked in "section options", the yellow dashed lines is there, but i cant pick them. its like i cant focus them.
in some tests i've discovered that if i uncheck "autochain", it works fine, or, if i use "filter" and select "curves" and make it pickable works fine too..
what's going wrong?
thank you for help and sorry if my english is bad.
