AVR FOR CAT'S GENERATOR
HI
WHO HAVE THE SERVICE MANUAL OF AVR SR4 OF CATERPILLER'S GENERATOR ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
AVR FOR CAT'S GENERATORAVR FOR CAT'S GENERATOR(OP)
HI
WHO HAVE THE SERVICE MANUAL OF AVR SR4 OF CATERPILLER'S GENERATOR ? Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: AVR FOR CAT'S GENERATOR
BTW- these regs stink. I have been swapping them with Basler SSRs for a few years now. A little more money, but they last a lot longer.
JTK
You need to spec digital VR, otherwise you get analog one.
i have some questions.
there're two "nuts" on AVR to adjust GAIN and VOLTAGE. i want to know how to adjust to get the right DROOD and VOLTAGE. And another question is : the system has three generators are paralleled. when the load changes, the power factors also change. how can i solve this problem?
The power factor problem requires power factor controllers. When you set a fixed output to parallel, that is the unity var setting when the breaker closes. When you add load the excitation needs to be increased in relation to the load.
The power factor controller can be set to a var or power factor setting (you want pf). It will constantly adjust power factor as the load varies.
We have used Basler SCP-250 power factor controls with the cat regulator you describe with good results. You need access to a current transformer for this to work.
JTK
