Turning below the centre line
Hi!
     Few days ago we had to do some work on a lathe that is retrofitted with cnc control.So the tool travels below the centre line means working area is -Y+Z plane.But I wasn't able to make a program for that.It's good only for modern lathes whose tool post moves on the other side(or back,+Y+Z plane)of job.So it will be great if somebody can tell how to do that!! We are using NX2.
