James G. MacGregor 3rd Edition, Design of Beam when b and d not Known
I have been trying to figuere out Example 4-6 on page 126 and I am having a hard time understanding a particular part.
In this example, on part 3:  b and d are computed using the following equation. (Msub_u/phi*ksub_n)=((bd^2)/12000).
Then on part 8:  it shows Msub_n= (Asub_s)*(fsub_y)(d-a/d).  When the numbers are plugged into this equation it is divided by 12000.  I know this has to do with the equation in part 3, but I am having a hard time trying to figuere out why.
I would appreciate if someone can help me figure this out, hope my explanation is not to confusing.
THANKS
RE: James G. MacGregor 3rd Edition, Design of Beam when b and d not Known
The 12000 is a unit conversion between in-lb and ft-kip.  From part 8:  5.58 (in^2) x 60000 (psi) * [33.0 in - (7.03/2) in] = 9871578 in-lb --> *(1 ft/12 in)*(1k/1000#) = 823 ft-k.
Hope that helps.
Thanks,  I just finished figuering that out.  SORRY. I spend some time trying to find out in the text and I was trying to somehow relate that 12000 in part 8 with the 1200 in equation part 3.  Make sense now.
THANKS
