indenting of vba code
I notice that vba is good at putting colors into my code to make it more readable.
I vaguely remember that it used to indent for readability but now it doesn't anymore.
This code ends up all left justified
If 3 > 2 Then
MsgBox ([var1])
End If
Why doesn't it indent the middle line?
RE: indenting of vba code
In the VBA editor check Tools=>Options, and select "Editor Tab".  I believe there is an "Auto Indent" checkbox on that form.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Cajun's solution will indent the next line if you have indented a line. So you'll have to indent pretty much yourself. A good - and free - automatic indenter is SmartIndent (http://www.bmsltd.ie/indenter/default.htm)
Cheers,
Joerd
Awesome. Thanks guys.
