rainfall and stream flow monitoring
We are trying to set up a system of monitoring station in the County to monitor rainfall and stream levels and transmit the data back to a central computer by radio.  Any suggestions?
RE: rainfall and stream flow monitoring
I believe Sacramento County, CA has such a system in place.  You may want to contact them and see what their experience has been.
good luck
Are you familiar with the real-time data available on the web from USGS?
http://waterdata.usgs.gov/usa/nwis/rt
The data for my area is about an hour old.  There's always a chance your stream might already be monitored.  If not, USGS may be able to give you some tips on setting up a remote guage.
Our state University has a site that has weather data with 5 minute updates (the rain end of your question)  The folks there may be helpful as well:
http://www.rec.udel.edu/TopLevel/Weather.htm
I would look into NOAA-NWS IFLOWS program. They also give grants to assist local communities purchase and maintain flood warning systems.
http://www.afws.net/
