Glass Corrosion
Glass Corrosion
Glass Corrosion
Is there anyone out there familiar with the chemical mechanisms of the surface corrosion of soda lime flat glass?
Henry Grover Jr.
Glass Tech Services
GTSForums@hotmail.com
RE: Glass Corrosion
Soda lime glass is actually slightly soluable in water. Strong caustic conditions will increase solubility. Dissolving is fairly slow so it is usually not noticed except in cases like fiberglass or in loss of surface polish. Corrosion of aluminum can create caustic and concrete is caustic.
RE: Glass Corrosion
Stress corrosion also occurs if stress and strong caustic conditions occur.  High temperatures accelerate both corrosion and stress corrosion.
