Limit to lighting elements?
I'm trying to insert 'point lights' into a lamp fixture design. There are more than 9 points I need, but Solidworks or Photoworks is only letting me add 8 point lights. Is this a memory limit in my computer or a program limitation? Is it possible to get around this?
Thanks!
Thanks!
RE: Limit to lighting elements?
You could try using Indirect Illuminiation in PW and setting your light material to constant. Anything with a constant setting in PW (when using ID) will give off a glowing (light) effect. This technique only works in some cases. It really depends on the render.
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com
SW 2006 SP 2.0
See thread559-134800 for more details and previews of what this looks like.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
