Fero- resonance
Fero- resonance
Fero- resonance
Is there any resouce available to assist with better understanding of this phenomonon or ways of overcomming the problem. The problem exists with single phase switching, fusing of three phase transformers connected to relatively long lengths of underground cable. I understand the resonance is a function of the cable capacitance and the impedance of the transformer. Probably the best way of overcomming the problem is by installing isolating links adjacent to the transformer but of course this increases the cost.
RE: Fero- resonance
Try ANSI/IEEE C57.105-1978 or later.  Section 7, page 22 has a good discussion of Ferroresonance.  Best of all, Section 9.2, page 32 has a bibliography with 27 references on Ferroresonance.  Item [8], "Abnormal Voltage Conditions Produced by Open conductors on 3-Phase Circuits Using Shunt Capacitors" is excellent.  It is from the December 1953 AIEE Transactions.  I have a copy I can fax you if you can't find a copy.  Just e-mail your fax number to gibbsdr@cepb.com if you want it faxed.
