Read data from ascii files using VBA
What should i do to read data from ascii files using VBA? I want to read the data and make a variable have the value i've read.
RE: Read data from ascii files using VBA
'Read One Line at a time
Dim sVal As String
Open ("C:\YourFile.txt") For Input As #1
Do While Not EOF(1)
Line Input #1,sVal
MsgBox sVal
Loop
Close #1
'Read a delimited file (2 columns of data)
Dim sVal1 As String,sVal2 As String
Do While Not EOF(1)
Input #1,sVal1,sVal1
MsgBox sVal1 & vbCrLf & sVal2
Loop
Close #1
The latter method can use any variable type. If you could provide more detail about the file you are trying to read I can whip up a better sample.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
