Updating list
Updating list
This is my first time doing something like this so please bear with me.
I am trying to set up a program using VB in Excel.
I have a master list of parts and prices.
Sub lists made up of parts and prices from the master.
Both the master list and sub lists on same worksheet.
I want to be able to update the master list then have the program update the sub list.
How can I have the program look for the same part in the master list to match it up with the sub list and enter the new price that I put in the master?
Make sense?
Make sense?
RE: Updating list
Cheers,
Joerd
RE: Updating list
*** master list ***
1 2 3
A ID part price
B 1 p1 $12
C 2 p2 $13
Z 25 p25 $1
*** sublist ***
1 2 3 (column numbers)
ID VLOOKUP formula VLOOKUP formula
Formula =VLOOKUP(1,$B$1:$Z$3,2) will return name of part with ID equal to 1. Formula =VLOOKUP(1,$B$1:$Z$3,3) will return price of part with ID equal to 1.
You can set up your sublist in a similar format as the master list: ID in first column, and VLOOKUP formulas in the second and third columns to get you part name and price. First parameter of VLOOKUP formula would be a cell name in the first column - when you change the ID in the first column, correct part name and price will be displayed.
Hope this helps,
bridgeart
www.bridgeart.net
RE: Updating list
joerd is absolutely correct - no vba is required. furthermore, you may want to consider using what is termed "dynamic arrays" or "ranges". please see the following examples at:
http://www.ozgrid.com/Excel/DynamicRanges.htm
hope this helps!
-pmover
a star for joerd!
RE: Updating list
