I got the logo in using a tiff file and insert pic...
Now its on the part but will not show up in our drawings..any ideas on how I can insert the logo on to the parts and so it will show up in my drawings?
RE: I got the logo in using a tiff file and insert pic...
You probably should have continued your original thread.
Is the primary purpose to show in the drawings?  If so, you can trace what you need in a sketch and either show the sketch in the drawing view or use the sketch to split the surfaces so the lines will show in the drawing view.
What you should do depends on your intent.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
If you apply your image as a decal or texture and you shade your drawing the image will show.  You can also just ole copy/paste the object directly into the drawing view.
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com
SW 2006 SP 2.0
Yes my intent is for4 them to show up in the drawings but I want them to be color an in the postion they have already been placed. I do not want to just copy and paste.
