DC voltage calculation
I am doing UPS 24VDC voltage calculation. Current drawn is 10A. I was told by my lead that I should use 20A for the voltage drop calculation when I use 1 way circuit length. This doesn't make sense to me. Because I am new to this Country. I want to make sure I did a right calculation.
RE: DC voltage calculation
BTW, my country is Sweden.
Gunnar Englund
www.gke.org
http://www.electrician.com/voltdrop/volt140.htm
h
http://www.nooutage.com/vdrop.htm
You may want to consider worst case due to the capability of the source and not preset load.
JTK
