electrolytic corrosion problem with SS440C & Ph.Bronze
Hi Freinds
Due to space problem i used bearings as Phosperous Branze as bearing with gear shafts made up of Stainless steel 440C.Now de problem is there any electrolytic corrosion problem occur in feature years of functioning?.
Thanx in before
John
Thanx in before
John
RE: electrolytic corrosion problem with SS440C & Ph.Bronze
What is the application environment, the bronze alloy, and is the 440C in Q+T condition?
