"broken" taps
"broken" taps
Hi everybody! New member to the forum! First thread.....have a quick question. Help!
I added a blind tap to a plate and when I add a thin cut/extrude line (scribe line) down the plate and thru the tap, it seems to "break" the tap in the drawing and the hole callout won't work! I can't really think of a better way to show the scribe line and still keep the tap linked with the hole callout. Any suggestions?
Thanks a bunch!
Thanks a bunch!
RE: "broken" taps
RE: "broken" taps
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: "broken" taps
MERRY CHRISTMAS
(Unabashedly Politically Incorrect)
RE: "broken" taps
Exactly how did you create your scribe line and what is its relation to the tap? I just tried to recreate your problem in SW2005 SP5.0 and SW2006 SP2.0 and holecallout works just fine in my tests. Could you post a simplified version of your part (nothing that would be considered proprietary by your employer) for us to look at? See FAQ559-1177 for instructions on how to do this.
Regg
