Fire Pump Controller (VFD)
I'm referring to my old thread184-20314 related to the above mentioned subject.
Actually the use of Variable speed fire pump controllers has been approved by NFPA 20 – 2003. you may refer to the following clause.
10.5.5   Variable Speed Pressure Limiting Control. Variable speed fire pump controllers shall be permitted provided that the following apply:
(1)     Upon failure of the variable speed pressure limiting control, the pump operates at rated speed.
(2)     The variable speed pressure limiting control is listed for fire service.
