Cannot connect to Database in Server Management Studio
THIS IS DRIVING ME NUTS!!
I currently can't connect to my database in SQL Server 2005 (enterprise) but as soon as I try to use any functions, I get cryptic errors found below.  I am about to pull my hair out.  Everything was working fine for around 4 days and now everything just blows up.  I've tried using both sql authentification and also windows:
Errors I'm getting (print screens):
http://www.photopizzaz.biz/junk/sqlserver_2005_errors_and_resolutions.doc
SQL logs:
http://www.photopizzaz.biz/junk/logs.txt
Event log errors are:
Event Type: Error
Event Source: MSSQLSERVER
Event Category: (4)
Event ID: 17809
Date:  12/21/2005
Time:  11:18:34 PM
User:  N/A
Computer: BG-SQL2005
Description:
Could not connect because the maximum number of '4' user connections has already been reached. The system administrator can use sp_configure to increase the maximum value. The connection has been closed. [CLIENT: <local machine>]
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 91 45 00 00 14 00 00 00   ?E......
0008: 0b 00 00 00 42 00 47 00   ....B.G.
0010: 2d 00 53 00 51 00 4c 00   -.S.Q.L.
0018: 32 00 30 00 30 00 35 00   2.0.0.5.
0020: 00 00 00 00 00 00         ......
Event Type: Failure Audit
Event Category: (4)
Event ID: 18456
Date:  12/21/2005
Time:  10:34:03 PM
User:  N/A
Description:
Login failed for user 'sa'. [CLIENT: <local machine>]
Data:
0000: 18 48 00 00 0e 00 00 00   .H......
0020: 00 00 07 00 00 00 6d 00   ......m.
0028: 61 00 73 00 74 00 65 00   a.s.t.e.
0030: 72 00 00 00               r...
Event Type: Information
Event Category: (2)
Event ID: 8561
Date:  12/21/2005
Time:  10:19:51 PM
User:  N/A
Description:
Recovery of any in-doubt distributed transactions involving Microsoft Distributed Transaction Coordinator (MS DTC) has completed. This is an informational message only. No user action is required.
Data:
0000: 71 21 00 00 0a 00 00 00   q!......
Event Type: Error
Event Source: Report Server Windows Service (MSSQLSERVER)
Event Category: Management
Event ID: 107
Date:  12/21/2005
Time:  4:46:14 PM
User:  N/A
Description:
Report Server Windows Service (MSSQLSERVER) cannot connect to the report server database.
RE: Cannot connect to Database in Server Management Studio
This doesn't really look like an engineering based problem. You will do better joining the sister site Tek-Tips (which is designed for computer professionals). When you've joined, look at http://www.tek-tips.com/threadminder.cfm?pid=962 which deals with SQL admin issues
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
