Torsional Vibration-Matrix Method
Hello there, I was looking for some help in calculating the second moment of area (I) value of a compressor blade. The I value changes throughout the section of the blade. The tip is at an angle of 15degrees from the base. I have used bd^3/12 for my base and INTy^2.dA for the tip(where y =sin15deg.s)I have tried to do it but the answers I get when put into my matrix spreadsheet do not tie in with initial Ansys analysis
Any help would be great
Thanks Jim
RE: Torsional Vibration-Matrix Method
THUNDERSCOT:  The equation you are using is for rectangles.  I am assuming that the turbine blade is airfoil shape.  The methods I suggest a dpeending upon the axis about which you want it are:
1.  Divide the blade into sections and do a calculation for each section about the axis of interest, then sum them up.
2.  Do it experimentally
Dave
