How to determine weld strength
Welds strength?
Is the weld strength govern by weld electrode or base metal? In LRFD, the strength is govern by electrode(Fexx=70ksi), and the area is weld neck area. But the AWS D1.3, the strength is govern by base metal strength and its thickness.
That makes a big difference on allowable load capacity calculations on weld joints.
has anybody had same issue?
RE: How to determine weld strength
You check the weld strength and the base metal strength and use the one that governs.
My understanding is that you select a welding rod that will produce a weld stronger than the part.  Then, the strength of the part governs.
