Max files for PDMworks to handle?
At what point does the PDMworks system lag in proformance?
100,000 files?
1,000,000 files?
more?
How many files to you manage? How many users do you manage?
Thank you for the input.
100,000 files?
1,000,000 files?
more?
RE: Max files for PDMworks to handle?
Maximizing Vault Performance
A large number of documents in a project degrades performance. More projects with fewer documents (fewer than 1000 or 2000 documents per project) results in better performance.
Clients can hide projects to improve performance.
If you operate over a network, network performance affects PDMWorks performance. PDMWorks cannot make a slow network faster.
____
The larger the vault to slower it will be to upgrade the files or reboot the server and rebuild the vault - I know a 10GB vault takes almost an hour to rebuild the tree.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
We have over 100k files in our vault, and dozens of users. The vault size is well over 100 GB, and our tree rebuild time is just under 30 minutes.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
