Dimensioning Query
Dimensioning Query
Is it Possible to list the names of dimensions used in features?(eg. the dimension controlling a draft angle in an extrude or the Number of instances in an array) Also is it possible to change the names of dimensions within features? (eg. change D1@extrude1 to A@extrude1)
Any Help greatly appreciated.
RE: Dimensioning Query
Tools > Options > System Options > General & select Show dimension names
Double click the feature or sketch in the Feature Manager.
RMB click on the dimension, select Properties.
Type a name in the Name box & click OK.
MERRY CHRISTMAS
(Unabashedly Politically Incorrect)
Been Looking for that for ages.
Happy New Year.
I set it up on a toolbar button... last week I think.
Works great...
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP02.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
Also, re: changing names...
I wrote a FAQ on this, as I found this to be good practice for parameters controlled by equations (avoids conflicts caused by SW recycling unused dimension names).
Simply RMB the dimension you wish to rename, select Properties, and change the name in the properties dialog.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
