Annotation Codes Documentation
Is there any documentation on all the different codes for NX3?
After messing around with the volume, surface area, etc. it got me wondering what else I can do.  Other than the GD&T codes and the typical symbols, diameter, etc.  What else is out there?
Anyone know.
RE: Annotation Codes Documentation
It's all in the help docs, finding it can be a bit tricky though :)
-Dave
Everything should be designed as simple as possible, but not simpler.
Amen to that guys.  I have hounded UGS to offer a comprehensive PDF file that has all of their documentation in it.  Like Gunman says, when using either help or the docs, you can start down one road and end up on another easily.
LC
Larry Coyle
Cylinder Head Engineering, LLC
www.cylinderheadengineering.com
