inventor degrees input in EXTRUDS
Hi there i'm working with Inventor 9 and i would like to know how can i input the angles in the TAPER part of the EXTRUSION OPERATION in %(percent) instead of in degrees...
I would like if somebody help me PLEEEASE
thanks guys!!!
RE: inventor degrees input in EXTRUDS
Did you purposely post this question in the Metal and Metallurgy engineering forum?  This should go in one of the Mechanical or software forums instead.
